  Visitors: 7779
CAD tip CAD tip # 12813:
How to set both upper and lower dimension tolerances as negative (or positive).
A - answer The tolerances displayed in the AutoCAD dimension text are by default set as lower-negative and upper-positive. But if you need to set tolerance limits both as negative or both as positive, you can enter their values with the minus sign (as differences).
Enter the value of either tolerance as negative.
Don't forget that the lower, negatively entered tolerance, may become the upper tolerance.
ACADACLTACADM
5.12.2020    5683×
Prices - CAD eShop:
applies to: AutoCAD · AutoCAD LT · AutoCAD Mechanical ·
Tip 13887:ClosestPt - the nearest point on another curve
Tip 13827:Snap points to the nearest curve/polyline with Snap2Curve.
Tip 13597:How to convert RGB color to Pantone, RAL, AutoCAD ACI, CMYK or vice versa?
Tip 13411:How do I set tolerances for several dimensions at the same time?
Tip 13402:Which products and features can I use for free with Flex Token licensing?
LogOff 2006 More info
