Over 1.096.000 registered users (EN+CZ). AutoCAD tips, Inventor tips, Revit tips. Try the new precise Engineering calculator. New AutoCAD 2026 commands and variables.
CAD tip CAD tip # 8718:
Question
How to display and dimension/annotate center of gravity of the individual subassemblies and parts in an Inventor assembly drawing?
You can use the following simple iLogic macro - when run, it creates/updates the location of the MyCOG workpoint in the model document:
Dim cogName As String = "MyCOG"
Dim doc As Document = ThisDoc.Document
Dim cog As WorkPoint
Try
cog = doc.ComponentDefinition.WorkPoints(cogName)
cog.SetFixed(doc.ComponentDefinition.MassProperties.CenterOfMass)
Catch
cog = doc.ComponentDefinition.WorkPoints.AddFixed(doc.ComponentDefinition.MassProperties.CenterOfMass)
cog.Name = cogName
End Try
Inventor
20.7.2012    13133×
Share the tip:
applies to: Inventor ·
Tip 8927:How to exclude parts of the Inventor assembly from total mass?
Tip 8286:How to display COG in Inventor drawing views?
Tip 5776:Automatic center of gravity for Inventor assemblies.
Tip 1198:Feature codes for Network License Manager.
Back    All CAD Tips
Categ:
DwgTextTranslator translates a series of drawings from one language to another using MS Access.
Download a fully functional trial version.
