  Visitors: 8800
CAD tip CAD tip # 7589:
Import and export IGES files in AutoCAD (DWG).
A - answer Since AutoCAD version 2011 with the installed "Subscription Advantage Pack" (SAP) and in versions 2012+ you can use the commands IGESIMPORT and IGESEXPORT.
With these commands you can import (read) and export (write) files in the neutral exchange format IGES (.igs, .iges). Both 2D and 3D objects are supported. The conversion is performed in the background (aruba.exe, AcTranslators.exe), a bubble notification in the AutoCAD status line informs about the finished process.
ACAD2012ACAD2011ADT2011Civil2011ABS2011
30.9.2010    33535×
Tip 12588:Which CAD formats can be be translated in Fusion 360 even without the cloud, offline?
Tip 12297:Which CAD formats are supported in the Autodesk Manufacturing Data Exchange Utility?
Tip 12184:Overview of CAD formats supported in Inventor 2020 (import/export/AnyCAD).
Tip 11337:Convert 3D PDF files back to CAD models.
Tip 10727:Easier scaling of Inventor parts.
