Over 1.096.000 registered users (EN+CZ). AutoCAD tips, Inventor tips, Revit tips. Try the new precise Engineering calculator and the updated Barcode generator. New AutoCAD 2026 commands and variables.
CAD tip CAD tip # 8834:
Question
One of the interesting functions of the 3D controller (mouse) 3dconnexion SpacePilot Pro is using its color LCD display for showing properties of the current 3D model (assembly).
This LCD panel displays by default the "LCD Workflow Assistant" - a legend (description) of current functions assigned to the programmable mouse buttons. These dynamic functions depend on the currently active Inventor environment (part, assembly, drawing, sketch, sheetmetal, piping...):
Button description
But with the "Model Properties Applet" you can also display physical and document properties of the currently edited model - its author, last save time/date, file size, mass and volume of the assembly, material, etc.:
Properties
Other options for the LCD panel are e.g. displaying Outlook e-mail and calendar or RSS channels.
So this vital information can be displayed all the time and it does not clutter your PC screen.
Inv
1.10.2012    7326×
Share the tip:
applies to: Inventor ·
Tip 10167:Keyboard shortcuts in Autodesk Fusion 360.
Tip 8819:I cannot rotate my DWG model in 3D with SpaceMouse.
Tip 8509:Unfold any 3D mesh into 2D planar form.
Tip 7503:Autodesk 3ds Max keyboard shortcuts.
Tip 7321:Pausing AutoCAD cursor in Windows 7.
Back    All CAD Tips
Categ:
