  Visitors: 13445
CAD tip CAD tip # 1329:
Can we run AutoCAD in terminal mode?
A - answer Yes, in the 2002 version.
A special 'self-hosted' build of AutoCAD 2002 (+Map,+CAD Overlay) has been made available - it supports (from both the license and technical view) the terminal mode, where the application runs on the server (Citrix, Windows 2000 server) and user workstation is only a terminal.
This special build has a separate installation mechanism and optimisations for the Citrix environment. It was available for Major Accounts with a minimum of 50 seats.
Since 2018, you can use virtualized environments for single-user subscription licenses of supported products.
ACAD2002Map5
15.5.2001    23252×
Prices - CAD eShop:
applies to: AutoCAD 2002 · AutoCAD Map 3D 5 ·
Tip 13633:How to run Revit, Inventor or Windows version of AutoCAD on macOS?
Tip 7890:How to find missing numbers in a series of numbered blocks?
Tip 5111:FlexLM (FlexNet) error code list.
Tip 2351:Can AutoCAD display Oracle Spatial graphical data?
Tip 1355:Is there AutoCAD, Inventor, 3D Studio or other Autodesk product available for Linux?
