  Visitors: 11430
CAD tip CAD tip # 1370:
How to make a PDF file from your drawing?
A - answer You can print directly (using the PLOT command) to a pseudo printer (device) "PDF Writer" or "Distiller Assistant" created by the Adobe Acrobat application (the full version, not the free 'Acrobat Reader'). Print parameters (format, colors, etc.) can be set in the same way as if you print on paper.
You can also use GhostScript to convert any postscript output from AutoCAD to a PDF format (or you can use other tools like OttoPDF, PDF995, JawsPDF, PDF-XChange, Win2PDF).
Since AutoCAD version 2007 you can plot directly to the PDF format using AutoCAD PLOT command. PDF output is also available in Inventor 2009 (and higher).
Alternatively you can publish drawings to the DWF format (Whip!). See the advantages and disadvantages of DWF vs. PDF in Tip 2027.
ACADMDTADTInventor
4.6.2001    42802×   FAQ
applies to: AutoCAD · MDT · AutoCAD Architecture · Inventor ·
Tip 13911:How to print all sheets at once from Inventor?
Tip 13826:Overview of a document history in Autodesk Docs.
Tip 13800:Visually compare 3D geometry in CAD and BIM files.
Tip 13778:How to publish several DWG drawings into one multi-page PDF?
Tip 13773:What is the maximum paper size when plotting from AutoCAD?
Link your AutoCAD block attributes with Excel tables/sheets. Automatically. Dynamically. Bidirectionally.
Try Excellink 2015 More info
