Over 1.092.000 registered users (EN+CZ). AutoCAD tips, Inventor tips, Revit tips. Try the new precise Engineering calculator. New AutoCAD 2026 commands and variables.
CAD tip CAD tip # 1813:
Question
You can set all Autosave parameters in the _Options command:
  1. files are saved in the C:\Documents and Settings\< usrname >\Local Settings\Temp\ directory by default but you can change it through the File location for automatic save on the Files tab or through the SAVEFILEPATH system variable
  2. you can disable autosave and set its timeout on the Open&Save tab (bottom left pane), or throught the SAVETIME variable (0=off)
Autosave files are deleted on successful exit of AutoCAD session.
ACAD2000
12.12.2001    73833×
Share the tip:
applies to: AutoCAD 2000 ·
Back    All CAD Tips
Categ:
