Over 1.092.000 registered users (EN+CZ). AutoCAD tips, Inventor tips, Revit tips. Try the new precise Engineering calculator. New AutoCAD 2026 commands and variables.
CAD tip CAD tip # 1818:
Question
Although it may sound impossible - you CAN draw multicolored lines/polylines in AutoCAD.
MLINE functionality can be used for this. Use the MLSTYLE command to define a new multiline style and define (element properties) two line elements, both with the offset equal to 0. Set different colors to them (e.g. green and red). Use different linetypes, e.g. DASHED and DASHED2 (you may need to Load them first) - for real-life applications you will probably need to define your own linetypes. Save the new Mline style. Now use the MLINE command to draw a polyline using this new mlstyle - it has alternating green/red colors! A true two-color (dual-color line)!
From BUDWEISER.DWG - multi-coloured entity
You can use the same approach to define even three or more colors.
As AutoCAD allows to define complex linetypes containing text, you can even make linetypes (mlines) with embedded text in a different color than the line (e.g. line in a BYLAYER color and text always in blue). For this you need to define one complex linetype containing text and almost no lines (e.g. only dots) plus a appropriate dashed linetype with spaces for the text. To see the principle you can define such multicolor text linetype using MLSTYLE with elements of DASHED and GAS (shipped with AutoCAD) linetypes. See the BUDWEISER benchmark drawing (DWG also downloadable from www.cadstudio.cz/download) for examples (benchmark #5).
ACAD
13.12.2001    93060×
Share the tip:
applies to: AutoCAD ·
Tip 13975:How to distinguish open tabs in Revit by project?
Tip 13579:Quick local opening of F3D files in Fusion 360.
Tip 11816:How to convert 3D CAD model to the format glTF 2.0 (GLB)?
Tip 11433:Should I use Win10 Game Mode for my AutoCAD, Inventor or Revit?
Tip 10607:How to export an Inventor 3D model to the IFC format?
Back    All CAD Tips
Categ:
Generate hatch patterns automatically from your DWG drawings with
HGEN 2006 More info
