  Visitors: 9875
CAD tip CAD tip # 2280:
How to translate drawing texts to another language? (DWG translation)
A - answer You can use the TRANS add-on utility (see www.cadstudio.cz) to translate drawing texts to another language (e.g. with Trados, Wordfast, Dejavu/DVX, or other CAT tool).
TRANS extracts Text and Mtext entities from DWG drawings into a text file (you can translate it using any automated text translation tool or by human translator) and then puts the translated texts back into your drawing (to the original places/positions and with the original properties). For batch processing multiple drawings (using script) set the FILEDIA variable to 0.
More information and download from the TRANS homepage. Drag the trans.vlx file into your AutoCAD session or use the APPLOAD command to load it. Use the TR_WRITE and TR_READ commands to export and then re-import your drawing texts. (This tool was not tested with double-byte languages or Unicode.)
The export text file looks like this:
{ID1}
text of the text entity number ID1
{ID2}
text of the text entity number ID2
The gTRANS command starts an automatic online translation of drawing texts using the Google Translate tool. You will just specify the language pair.
For TRADOS: Type the TR_WRITE command in the command line and press Enter. Select the TXT filename for output. Select the complete drawing or just the parts of the drawing you want to translate and press Enter (make sure all text layers are on and unlocked). Open the exported TXT file in Word and save it as RTF. Translate the RTF file with Trados - do not change the text in parenthesis {}. Clean the translated RTF file. Open the cleaned RTF file and save it as TXT (text only). Return back to AutoCAD and enter the command TR_READ. Locate the translated TXT file - the texts in your drawing will be replaced with the translated text.
Use TRANS version 1.2 or higher for long MTexts.
gTRANS in action:
click to start animation
Using automatic translation via Google Translate
(click to start animation)
See also the YouTube video on using TRANS:
ACADMDTADTMap
20.6.2002    94231×   FAQ
Prices - CAD eShop:
DwgTextTranslator translates a series of drawings from one language to another using MS Access.
Download a fully functional trial version.
Tip 13855:DBXscanLayers and DBXscanBlocks - bulk report content of DWG files in a folder.
Tip 13824:How to export OBJ including materials, textures from Inventor?
Tip 13766:Edit the Fusion 360 CAM tool library using Excel.
Tip 13557:How to create an image with transparent background in Fusion 360?
Tip 13485:Multi-line keynotes in Revit.
Add .CIT raster format support to AutoCAD and Map and Civil 3D
CITin More info
