  Visitors: 13694
CAD tip CAD tip # 2580:
How to redirect text window output to a file?
A - answer You can use the _LOGFILEON command to echo all text window output to a file. The output file will be saved in AutoCAD directory with the name-pattern of drawingname_x_x_xxxx.log. Logging can be switched off using _LOGFILEOFF.
ACADADTMDT
5.10.2002    9521×
Prices - CAD eShop:
applies to: AutoCAD · AutoCAD Architecture · MDT ·
