  Visitors: 8548
CAD tip CAD tip # 2869:
Error message: File was created by an incompatible version of AutoCAD.
A - answer or: Drawing file not valid, not a valid file
You are probably trying to open an AutoCAD 2009/2008/2007 drawing in AutoCAD 2006, an AutoCAD 2011 drawing in AutoCAD 2004, or an AutoCAD 2004 DWG file in AutoCAD 2000/2000i/2002 (generally: a newer DWG format in an older AutoCAD version). Or your DWG file is corrupted.
In the source AutoCAD version, re-save your file into a compatible (older) DWG file format (using the SAVEAS command or OPTIONS > Open&Save > Save As), or upgrade to the current version of your Autodesk product (e.g. 2015).
You can also use the offical DWG-version-converter (free) - "Autodesk DWG TrueView 2015" (see Download).
ACAD2010ACAD2008ACAD2004ACAD2000LT
27.2.2003    87945×   FAQ
Prices - CAD eShop:
Tip 13849:How to install a custom font in AutoCAD Web?
Tip 13800:Visually compare 3D geometry in CAD and BIM files.
Tip 13784:Export block coordinates to a table. How to use the DATAEXTRACTION command in AutoCAD LT?
Tip 13688:How to select all DWG objects of a certain type in AutoCAD LT? (texts, circles...)
Tip 13683:Limitations of the LISP language (AutoLISP, VisualLISP) in AutoCAD LT - what to watch out for
DwgTextTranslator translates a series of drawings from one language to another using MS Access.
Download a fully functional trial version.
