  Visitors: 5392
CAD tip CAD tip # 3389:
Express Viewer doesn't display properties of individual drawing objects.
A - answer Properties of the selected entities (Properties window) are displayed only with objects and properties published using the "Interoperability and Productivity Extension" for Architectural Desktop 2004.
E.g. the door object can display the manufacturer's name, material or fire class.
Architectural Desktop 2005 supports full publishing of AEC object properties. You can view them in Autodesk DWF Viewer and DWF Composer.
ADTViewDWF
3.11.2003    7522×
Prices - CAD eShop:
Tip 12325:How to display a DWG from Advance Steel including AS objects? (AST viewer)
Tip 10301:How to export PDF with hyperlinks from AutoCAD?
Tip 9884:Wrong color on monochrome DWG prints from AutoCAD Mechanical.
Tip 9363:How to hide the frame of a wipeout, embedded DWF or DGN?
Tip 9030:Precise loading of PDF files into Autodesk Design Review (and PDF-to-DWF)
