Over 1.092.000 registered users (EN+CZ). AutoCAD tips, Inventor tips, Revit tips. Try the new precise Engineering calculator. New AutoCAD 2026 commands and variables.
CAD tip CAD tip # 4325:
Question
The RText (remote text) contents can be a Diesel expression or an external file. Control characters are disabled in RText by default. The underline control chars are \L and \l.
To enable processing of control characters (like in MText) also in RText objects, use an undocumented setting - bit 2 in the DXF group 70.
Try e.g. the following code which creates an underlined RText:
(entmake '((0 . "RTEXT")
(100 . "AcDbEntity")
(100 . "RText")
(10 10.0 10.0 0.0)
(40 . 0.3)
(70 . 3)
(7 . "Standard")
(1 . "UNDERLINED {\\LTEXT}") ) )
Make sure you have used the RTEXT command at least once in the current session.
ACAD2000ADTMap
4.4.2005    17289×
Share the tip:
Tip 14363:Yesterday's, tomorrow's, past or future date in the DWG drawing.
Tip 13426:Use of alternative units for arithmetic in dimensions (without square brackets).
Tip 8989:Control codes "%%" in text entities.
Tip 8640:Text formatting codes in MText objects.
Tip 7191:How to increase the offset between MLeader text and underline?
Back    All CAD Tips
Categ:
DwgTextTranslator translates a series of drawings from one language to another using MS Access.
Download a fully functional trial version.
