Over 1.092.000 registered users (EN+CZ). AutoCAD tips, Inventor tips, Revit tips. Try the new precise Engineering calculator. New AutoCAD 2026 commands and variables.
CAD tip CAD tip # 8989:
Question
In AutoCAD text (DText, etc.) you can use control codes prefixed with "%%" to enter special characters and formatting (may depend on a font, works fine with standard AutoCAD fonts). Besides the format "%%nnn" which can be used to enter a character with the internal code nnn, you can use the following special codes:
%%c   diameter character (Ø)
%%d   degree character (°)
%%u   toggles underline mode
%%o   toggles overline mode
%%k   toggles strikethrough mode (since 2013)
%%p   tolerance character, plusminus (±, +-)
%%%   percent character (escape)
ACADACLT
22.12.2012    15318×
Share the tip:
applies to: AutoCAD · AutoCAD LT ·
Tip 14446:Undocumented options in AutoCAD FIELDs - hyperlinks, hexadecimal or binary format
Tip 14392:How to get rid of the dot displayed by P&ID symbols in Plant 3D?
Tip 14384:Wrong encoding of XLS/CSV/TXT files exported from CAD. Wrong characters on command line.
Tip 13831:ReplMTcol - recoloring parts of text in paragraph Mtext.
Tip 13485:Multi-line keynotes in Revit.
Back    All CAD Tips
Categ:
Increase your productivity with our set of add-on functions for AutoCAD Civil 3D
CADstudio Civil Tools More info
