Over 1.092.000 registered users (EN+CZ). AutoCAD tips, Inventor tips, Revit tips. Try the new precise Engineering calculator. New AutoCAD 2026 commands and variables.
CAD tip CAD tip # 5277:
Question
You can copy and drag entities by mouse not only inside a drawing but also between two different DWG drawings.
In AutoCAD, open and display both (source + target) drawing windows. Select an object in the source drawing (by left mouse button - grip select). Now press and hold the right mouse button and drag the object to the other (target) window. Release the mouse buton and from the context menu select "Copy here", or "Insert to original coordinates".
If you copy a block reference, its block definition is copied as well.
ACADACLT
17.11.2006    17719×
Share the tip:
applies to: AutoCAD · AutoCAD LT ·
Tip 14532:Two options for inserting images into DWG in AutoCAD Web app.
Tip 14417:Quick calculator on an AutoCAD keyboard shortcut.
Tip 14321:How to re-dock a dragged model-tree browser window in Fusion?
Tip 13997:4 methods of 3D orbit in Inventor, with specified pivot.
Tip 13723:How to tear and drag a DWG drawing window to a second screen?
Back    All CAD Tips
Categ:
