Over 1.098.000 registered users (EN+CZ).
AutoCAD tips, Inventor tips, Revit tips.
Try the new precise Engineering calculator and the updated Barcode generator.
New AutoCAD 2026 commands and variables.
CAD tip # 5354:
Question
If you see disabled buttons Raytrace, Radiosity and other Revit rendering functions, you have probably set a wrong path to the rendering folder - typically:
c:\Documents and Settings\All Users\Application Data\Autodesk\Revit Building 9\RenderingYou can find this setting in the dialog Settings > Options > Rendering.
The folder may not contain the neccessary files and the downloaded Accurender contents (libraries).
Revit9Revit8Revit7
12.1.2007
17557×
