  Visitors: 5333
CAD tip CAD tip # 5437:
Trim lines to blocks.
A - answer If you need to use a block (entities inside a block reference) as a boundary to trim (or extend) other lines in a drawing, use the BTRIM (or BEXTEND) command from Express Tools.
Beside blocks you can also use boundaries defined by line entities nested in Xrefs.
ACAD
26.2.2007    23606×
Prices - CAD eShop:
applies to: AutoCAD ·
Tip 13847:Pringles in AutoCAD - a hyperbolic paraboloid.
Tip 13694:Individual modification of elements in AutoCAD dynamic arrays.
Tip 13131:How to crop an image or PDF underlay in Revit?
Tip 12966:TrimArr - trim a dynamic array to a boundary curve.
Tip 12392:Export unfolds of sheetmetal parts to DXF - parameters for iLogic and VBA
