Over 1.092.000 registered users (EN+CZ). AutoCAD tips, Inventor tips, Revit tips. Try the new precise Engineering calculator. New AutoCAD 2026 commands and variables.
CAD tip CAD tip # 5878:
Question
You can use the sequence of 3DSOUT (export) and 3DSIN (import) commands to change 3D solids to mesh surface models.
See tip 5516 for 3DSOUT in AutoCAD 2007/2008.
See the Sol2Mesh utility for AutoCAD 2011/2012 and higher - DL Download
ACADADT
29.11.2007    20519×
Share the tip:
applies to: AutoCAD · AutoCAD Architecture ·
Tip 14472:Overview of CAD formats supported in Inventor 2026 (import/export/AnyCAD).
Tip 14095:How to increase the accuracy (smoothness) of STL files exported from AutoCAD?
Tip 14075:Overview of CAD formats supported in Inventor 2025 (import/export/AnyCAD).
Tip 13472:How to convert the structure of a volumetric lattice to a real mesh body?
Tip 13021:Rotating model when hovering above a 3D point cloud. How to disable?
Back    All CAD Tips
Categ:
