  Visitors: 7452
CAD tip CAD tip # 13021:
Rotating model when hovering above a 3D point cloud. How to disable?
A - answer Switch off the system variable UCSDETECT (set to 0). This variable controls the automatic dynamic alignment (rotation) of the UCS if your cursor is over a planar surface of a 3D solid, a planar mesh or a planar segment of a point cloud.
By default, the plane detection is on (1).
If you see performance problems, set UCSDETECT to 0.
ACADADTPlantACADMCivilMap
25.7.2021    1739×
Tip 13938:ModDXF - utility for bulk modification/display of internal DXF properties in DWG entities.
Tip 13514:Why does the Power dimensioning command zoom my drawing?
Tip 12837:RenameCSV - rename layers, blocks, layouts, views, linetypes using Excel tables
Tip 12766:Lines with a single grip, incorrect osnaps, intersections, offsets, hatches - CheckLarge
Tip 11847:Automatic UCS aligned with the current View (UCSauto switch).
