Over 1.092.000 registered users (EN+CZ). AutoCAD tips, Inventor tips, Revit tips. Try the new precise Engineering calculator. New AutoCAD 2026 commands and variables.
CAD tip CAD tip # 5968:
Question
The non-dialog (line) version of the MAPIMPORT command for importing GIS data from foreign formats offers only these options (file types): FDO_SDF, ARCINFO, E00, SHP, FDO_GEN, GML, MIF, MAPINFO, IGDS, DNF, SDTS, VPF.
If you miss the DGN format - it is hidden under the name "IGDS" (Interactive Graphics Design Software). This is the original file format which was used to define the ISFF (Intergraph Standard File Format), and DGN is based if ISFF.
MapCivil
31.1.2008    7180×
Share the tip:
applies to: AutoCAD Map 3D · Civil 3D ·
Tip 10636:The entity isn't planar to the World Coordinate System and can't be converted.
Tip 9862:How to import a DGN 3D model into Autodesk Inventor?
Tip 9739:Size of a saved DWG file grows unexpectedly.
Tip 9698:Data formats supported in Autodesk InfraWorks 360.
Tip 9553:Complete thorough PURGE on a single click.
Back    All CAD Tips
Categ:
DwgTextTranslator translates a series of drawings from one language to another using MS Access.
Download a fully functional trial version.
