Over 1.092.000 registered users (EN+CZ). AutoCAD tips, Inventor tips, Revit tips. Try the new precise Engineering calculator. New AutoCAD 2026 commands and variables.
CAD tip CAD tip # 5991:
Question
Using the dynamic blocks functionality in AutoCAD you can prepare a block with an attribute (label) which will always maintain its horizontal (readable, legible) orientation even when you rotate the block.
As an example of such dynamic label block you can try the DWG block Mark1 from the Block Library. As you can see on the demo, this block keep its attribute (text) position both when rotated using its dynamic properties and when rotated using the standard ROTATE command:
Block Mark1 - rotating
An annotative attribute is used, in a viewport-aligned style.
ACADACLTADTMap
19.2.2008    18599×
Share the tip:
Tip 14537:Automation of AutoCAD drawing texts using fields.
Tip 14526:How to export geometry from AutoCAD DWGs to JSON files and import it back?
Tip 14446:Undocumented options in AutoCAD FIELDs - hyperlinks, hexadecimal or binary format
Tip 14443:Connector, notch, groove, cutout or other curve- breaks - easily with dynamic blocks.
Tip 14402:What is the difference between the BLOCKREPLACE, BREPLACE, REPLACEBLOCK, RIBLOCK and BLKREDEF commands?
Back    All CAD Tips
Categ:
