Over 1.092.000 registered users (EN+CZ).
AutoCAD tips, Inventor tips, Revit tips.
New AutoCAD 2026 commands and variables.
CAD tip # 6607:
Question
If you need to import existing view definitions from an older DWG file to your current drawing, you can use the free utility CADstudio CopyViews.
Load the CopyViews.vlx file with APPLOAD, start the CopyViews command and specify the source drawing. All its named views are copied over to your current drawing.
You can download CopyViews from Download
ACADADTMapCivilACADMABS
31.3.2009
18015×
applies to: AutoCAD · AutoCAD Architecture · AutoCAD Map 3D · Civil 3D · AutoCAD Mechanical · AutoCAD/Revit MEP ·
