  Visitors: 4922
CAD tip CAD tip # 6609:
Reverse sample line numbering for river flow alignments.
A - answer If you use AutoCAD Civil 3D for river flow alignments, you probably want to number your sample lines "backwards" - in the opposite way than Civil does it. Both the stationing (river log) and the sample lines should be measured from the river estuary.
The sequential numbering of sample lines (the river profile) can be reversed using the free CADstudio Civil-SPRx utility. Civil-SPRx can be downloaded from here.
Just load the VLX application, start the SPRX command and select either the whole sample line group, or the individual sample lines to renumber.
Sample lines - river
See the video:
Civil2009
31.3.2009    10287×
Prices - CAD eShop:
applies to: Civil 3D 2009 ·
Tip 13635:How to speed up background publishing in AutoCAD?
Tip 13305:Where can I find the icon to run Civil 3D 2023 as AutoCAD?
Tip 12191:How to preset options in the Purge dialog?
Tip 12049:AutoCAD display (status bar) jumps and flickers while zooming.
Tip 11970:How to find the map coordinate system of a drawing?
DwgTextTranslator translates a series of drawings from one language to another using MS Access.
Download a fully functional trial version.
