  Visitors: 8890
CAD tip CAD tip # 6613:
How to make your AutoCAD slower?
A - answer Usually you want to do just the opposite. But there are situations where you need to pause and wait for something - to display a slide, to read a message or result, to debug your code.
If you want to pause the execution of your menu macros, scripts or LISP utilities, you can use the DELAY command. On its prompt enter the number of milliseconds to wait. Be carefull when entering large numbers - AutoCAD will really "hang" (freeze) for the specified time (may be good for office pranks :-).
DELAY 0 is also the best "NOP" (no operation) command - it doesn't do anything.
ACADLT
2.4.2009    8177×
Prices - CAD eShop:
applies to: AutoCAD · AutoCAD LT ·
Tip 13459:DWG drawing version history directly in AutoCAD.
Tip 12075:How to display a temporary iLogic message, just for a couple of seconds?
Tip 11354:Animate dyn.block parameters and dim.constraints in AutoCAD DWGs.
Tip 9962:Revit: long delay after you click on the application menu ("R")
Tip 9156:I have enabled saving to cloud but my newly saved DWG is not in the cloud.
