  Visitors: 8672
CAD tip CAD tip # 829:
How to get rid of the unwanted control characters in MTEXT entities?
A - answer For a global change use the MTEXTCF freeware utility (by J.Bastecky), downloadable from Download.
You can also use the right-click function "Remove formatting" in the MText editor to remove the formatting codes individually.
For MTEXTs, DIMENSIONs, MLEADERs and TABLEs - see UnFormat - Download.
ACAD
10.12.2000    7033×   FAQ
Prices - CAD eShop:
applies to: AutoCAD ·
Tip 13911:How to print all sheets at once from Inventor?
Tip 13855:DBXscanLayers and DBXscanBlocks - bulk report content of DWG files in a folder.
Tip 13824:How to export OBJ including materials, textures from Inventor?
Tip 13737:Formatting leading zeros in AutoCAD fields (and automatic field update).
Tip 13712:Why do I have an inactive "thousands separator" item in AutoCAD text field formatting?
Generate hatch patterns automatically from your DWG drawings with
HGEN 2006 More info
