Over 1.095.000 registered users (EN+CZ). AutoCAD tips, Inventor tips, Revit tips. Try the new precise Engineering calculator. New AutoCAD 2026 commands and variables.
CAD tip CAD tip # 10972:
Question
With the freeware aplication FLD2TXT you can globally replace dynamic text fields in your drawing with static text strings representing their current values.
Download this CAD Studio's utility from DL Download, load it with APPLOAD and type the command FLD2TXT. You can choose whether to proces just the modelspace fields, paperspace fileds, or all of them.
This tool converts standalone fields, fields in MTexts and Multileaders, in Dimensions and in block Attributes.
ACAD
20.6.2016    9425×
Share the tip:
applies to: AutoCAD ·
Tip 14604:QRcode - dynamically generated QR codes in AutoCAD.
Tip 14537:Automation of AutoCAD drawing texts using fields.
Tip 14446:Undocumented options in AutoCAD FIELDs - hyperlinks, hexadecimal or binary format
Tip 14363:Yesterday's, tomorrow's, past or future date in the DWG drawing.
Tip 14307:How do I generate EDU licenses for the Autodesk license server?
Back    All CAD Tips
Categ:
LogOff 2006 More info
