Over 1.092.000 registered users (EN+CZ). AutoCAD tips, Inventor tips, Revit tips. Try the new precise Engineering calculator. New AutoCAD 2026 commands and variables.
CAD tip CAD tip # 7790:
Question
If you have closed (disabled) your AutoCAD ribbon by mistake, you can restore it and display it again with the RIBBON command.
You can also restore it by switching the AutoCAD workspace - to another one and back to the current.
ACAD2011ACAD2010ADTACADM
12.2.2011    34516×
Share the tip:
Tip 14402:What is the difference between the BLOCKREPLACE, BREPLACE, REPLACEBLOCK, RIBLOCK and BLKREDEF commands?
Tip 14359:Automatic macro execution when opening a CAD file (AutoCAD, Inventor, Max, PowerMill)
Tip 14354:Bit-encoded value of the undocumented variable INPUTSEARCHOPTIONFLAGS.
Tip 14248:How to run Dynamo script from LISP, menu or .SCR script in Civil 3D?
Tip 14135:New special code ^] for menu-macros, easy object selection.
Back    All CAD Tips
Categ:
VRMLout More info
