Over 1.092.000 registered users (EN+CZ). AutoCAD tips, Inventor tips, Revit tips. Try the new precise Engineering calculator. New AutoCAD 2026 commands and variables.
CAD tip CAD tip # 14527:
Question
Use the following iLogic macro to easily search and bulk-replace arbitrary text in Inventor IDW or DWG drawings. You can use either regular expression mode or plain text string search/replace (see USEREGEX settings in line #2).
Text will be replaced in general notes, leader notes, dimensions, tables (except BOM/parts lists), title blocks and sketched symbols.
Create the following iLogic macro and run it on the active sheet in your Inventor drawing.
'Search/Replace drawing texts - 2025, www.cadforum.cz
Class ReplaceClass
Dim USEREGEX = True 'regular expressions, case sensitive OR plain substring, insensitive
Dim repcount As Integer = 0
Sub Main
	If ThisDoc.Document.DocumentType <> DocumentTypeEnum.kDrawingDocumentObject Then
		MsgBox("A Drawing document must be active", vbCritical, "")
		Exit Sub
	End If
	Dim oSheet As Sheet = ThisDrawing.Document.ActiveSheet
	Dim oTextBox As TextBox
	Dim oldText As String
	Dim newText As String
	Dim oldprompt As String = "case insensitive match, no wildcards"
	Dim newprompt As String = ""
	'prompt for search/replace strings:
	If USEREGEX Then
		oldprompt = "regular expression; case sensitive; use () for capture groups, \d as number, .* as wildcards, \ as escape"
		newprompt = "regular expression; use $1,$2 as capture groups, \ as escape"
	End If
	oldText = InputBox("String to find (old):" & vbCrLf & vbCrLf & oldprompt, "iLogic - Replace", "old")
	If oldText = "" Then Return 'exit rule
	newText = InputBox("String to replace '" & oldText & "' with:" & vbCrLf & vbCrLf & _
						newprompt & vbCrLf & vbCrLf & _
						"(replaces notes, leaders, dimensions, tables, sketches, titleblocks)", _
						"iLogic - Replace", "new")
	If newText = "" Then Return 'exit rule
	'error handling
	On Error Resume Next
	'look in General Notes
	For Each oGeneralNote In oSheet.DrawingNotes.GeneralNotes
		oText = oGeneralNote.FormattedText
		oText = ReplaceText(oText, oldText, newText)
		oGeneralNote.FormattedText = oText
	Next
	'look in Leader notes
	For Each oLeaderNote In oSheet.DrawingNotes.LeaderNotes
		oText = oLeaderNote.FormattedText
		oLeaderNote.FormattedText = oText
	Next
	'look in Dimensions
	For Each oDimension In oSheet.DrawingDimensions
		oText = oDimension.Text.FormattedText
		oDimension.Text.FormattedText = oText
	Next
	'look in Tables
	For Each oTable In oSheet.CustomTables
		oTable.Title = ReplaceText(oTable.Title, oldText, newText) ' Title
		Dim oRows As Inventor.Rows = oTable.Rows
		For Each oRow As Inventor.Row In oRows
			For Each oCell As Inventor.Cell In oRow
				oCell.Value =  ReplaceText(oCell.Value,oldText, newText) ' Cells
			Next 'oCell
		Next 'oRow
	Next
	'look in Title blocks
	Dim oTitleBlock = oSheet.TitleBlock
	For Each oTextBox In oTitleBlock.Definition.Sketch.TextBoxes
		oText = oTitleBlock.GetResultText(oTextBox)
		oTitleBlock.SetPromptResultText(oTextBox, oText)
	Next
	'look in Sketched symbols
	For Each oSymbol In oSheet.SketchedSymbols
		For Each oTextBox In oSymbol.Definition.Sketch.TextBoxes
			oText = oSymbol.GetResultText(oTextBox)
			oSymbol.SetPromptResultText(oTextBox, oText)
		Next
	Next
	MsgBox("Performed " & repcount & " replacements","Replacements")
End Sub
Function ReplaceText(oText As String, oldText As String, newText As String)
	Dim prev As String
	prev = oText
	If USEREGEX Then
		oText = System.Text.RegularExpressions.Regex.Replace(oText,oldText,newText)
		If oText <> prev Then repcount = repcount + 1
	Else
		If oText = oldText Or oText.Contains(oldText) Then
			oText = Replace(oText, oldText, newText)
		End If
	End If
	Return oText
End Function
End Class
Inventor
6.5.2025    631×   FAQ
Share the tip:
applies to: Inventor ·
Tip 14489:Multiline header of a parts list in an Inventor drawing.
Tip 14236:How to add color background (underlay mask) to Inventor dimension texts?
Tip 13911:How to print all sheets at once from Inventor?
Tip 13703:How to generate a dynamic QR code or Data Matrix on an Inventor drawing?
Tip 13599:How to read iProperties from Inventor models and drawings in AutoCAD DWGs?
Back    All CAD Tips
Categ:
VRMLout More info
