  Visitors: 5040
CAD tip CAD tip # 12069:
Unicode and DXF files.
A - answer Texts (contents of text objects) represented in the DXF interchange format files (a textual version of DWG) were stored in plain ASCII up to AutoCAD version 2017. Special characters - e.g. czech, asian, cyrillic - were expressed using either the MIF (Maker Interchange Format, syntax: M+nxxyy) or CIF (Common Interchange Format, syntax: U+nnnn) codes.
Since version 2007, DXF files and saved and loaded in Unicode (UTF-8). So any special characters can be also stored directly to the DXF. But they can still be interpreted from the MIF and CIF codes. When interpreting the codes, the current setting of the DWGCODEPAGE variable is applied.
ACADLTDWG
29.11.2018    4084×
Prices - CAD eShop:
applies to: AutoCAD · AutoCAD LT · DWG ·
Tip 13541:Using Twinmotion from Revit to visualize other types of 3D scenes.
Tip 12421:Wrong units in an imported DXF file.
Tip 12347:Invalid or incomplete DXF input -- drawing discarded.
Tip 10903:How to import an Illustrator file (.AI) into AutoCAD (.DWG)?
Tip 10279:Which formats can be exported from configured models in Configurator 360?
Automatic nesting of 2D parts on rectangular sheets in AutoCAD
AutoNEST 2008 More info
