Over 1.096.000 registered users (EN+CZ).
AutoCAD tips, Inventor tips, Revit tips.
Try the new precise Engineering calculator and the updated Barcode generator.
New AutoCAD 2026 commands and variables.
CAD tip # 9506:
Question
If you find files with the extension .AXM in your Autodesk 360 document repository, these are models created in one of the versions (Android, iPad, web)of the cloud application Autodesk FormIt for conceptual BIM modeling (architecture). These files are usually located in the "FormIt" folder.
Newer versions of FormIt save the same model also in the .RVT format (for Revit). You can also import AXM files in Revit through the FormIt 360 Converter add-on application.
FormItRevitA360
19.10.2013
10914×
