  Visitors: 5176
CAD tip CAD tip # 7992:
What is the file format .123D?
A - answer Files with the extension .123d (and similarly .123c) are stored from the CAD application "Autodesk 123D".
Internally, these files are just 3D DWG files - so can rename them to .dwg to open them in the latest version of AutoCAD. Similar DWG files are stored from Inventor Fusion.
DWGFusion123D
19.5.2011    10048×
Prices - CAD eShop:
applies to: DWG · Fusion 360 · 123D ·
Tip 13513:How to quickly record a video from a CAD application or other Windows program? (replacing Screencast)
Tip 13433:How to create a parametric dynamic 3D block in AutoCAD?
Tip 13402:Which products and features can I use for free with Flex Token licensing?
Tip 13228:DWG or DXF file exported to/from Fusion 360 has incorrect size (scale, 10x larger/smaller).
Tip 13227:Reference Explorer - quick analysis of your project or assembly (file size, xref errors).
LogOff 2006 More info
