  Visitors: 8632
CAD tip CAD tip # 10923:
Which Autodesk products do support the IFC format?
A - answer The following Autodesk products and product families in versions 2016, 2017 and higher directly support data files in the BIM Exchange format IFC (Industry Foundation Classes).
  • A360 (View, Team, Mobile...)
  • Advance Steel
  • AutoCAD Architecture
  • AutoCAD MEP
  • AutoCAD Civil3D
  • BIM360 Glue
  • Fabrication CADmep
  • Fabrication ESTmep
  • InfraWorks 360
  • Inventor
  • Navisworks
  • Revit (Architecture, Structure, MEP) - IFC certification
  • Revit LT - IFC certification
  • Robot Structural Analysis Professional
The IFC format is maintained by the organization buildingSMART. This body also officially certifies software tools supporting .IFC.
See also Autodesk IFC, IFC on BIMfo.cz and the IFC format.
ACADADTRevitNWInvFabricationSteel
26.5.2016    5283×
Tip 13404:How to import an IFC file in AutoCAD?
Tip 12355:Revit support for older versions of the IFC format.
Tip 12325:How to display a DWG from Advance Steel including AS objects? (AST viewer)
Tip 12184:Overview of CAD formats supported in Inventor 2020 (import/export/AnyCAD).
Tip 10607:How to export an Inventor 3D model to the IFC format?
