RSS discussions
Discussion Discussion forum
Topic Closedzooming problem
 Post Reply Post Reply
Author
Arben.Allaraj View Drop Down
Senior Member
Senior Member
Using: AutoCAD 2008
Status: Offline
Direct Link To This Post Topic: zooming problem
    Posted: 29.Jan.2008 at 16:11
Originally posted by 5han3 5han3 wrote:
whats the default??
Check this :
Ing Arben.Allaraj
http://cad-drafting-corner.blogspot.com
Back to Top
5han3 View Drop Down
Newbie
Newbie
Status: Offline
Direct Link To This Post Posted: 29.Jan.2008 at 16:04
whats the default??
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2008
Status: Offline
Direct Link To This Post Posted: 29.Jan.2008 at 14:19
 Check the ZOOMFACTOR VARIABLE.
Ing Arben.Allaraj
Back to Top
Newbie
Newbie
Status: Offline
Direct Link To This Post Posted: 28.Jan.2008 at 14:05
i have tryied to delete everything by zoomin out but it doesnt seem to pick anything up, and yes it is only the plan is inserted into.
Back to Top
Rman View Drop Down
Groupie
Groupie
Status: Offline
Direct Link To This Post Posted: 16.Jan.2008 at 01:37
You said you want to insert a new plan into a drawing, are there any entities in the drawing before you do inserting? If the answer is yes, you need to make sure the location\coordination (x,y) between both of them when inserting. Possibly the location between them is too far away, so  their view become to small because AutoCAD interface want to show us whatever entities within the drawing.
Or, alternatively, try insert your new plan into a new drawing. Let see what will happened.
Back to Top
Breeze104 View Drop Down
Senior Member
Senior Member
Using: Production Design Suite Premium 2015
Status: Offline
Direct Link To This Post Posted: 15.Jan.2008 at 14:45
Have you tried to paste it @ a different location and then move it to 0,0?
Also, you might have something hanging out of normal view.  After you have zoomed to extents try to zoom a bit further out and then try erasing all around the outside of the plan you might find that there is actually someting out there causing the problem.
Edited by Breeze104 - 15.Jan.2008 at 14:51
Breeze
Back to Top
Newbie
Newbie
Status: Offline
Direct Link To This Post Posted: 15.Jan.2008 at 14:28
erm yes i have checked the layers and there all on and set the UCSFOLLOW to 0. the problem is when i paste the plan into the drawing anywhere and do zoom all or extent it will zoom in on the plan, but if i paste the plan at 0,0 and zoom it gets smaller??? the problem is i need to paste it at 0,0
Back to Top
Rman View Drop Down
Groupie
Groupie
Status: Offline
Direct Link To This Post Posted: 15.Jan.2008 at 09:22
Have you check with Layer Manager to see wether any layers has been turn off?
Back to Top
Belianis View Drop Down
Newbie
Newbie
Status: Offline
Direct Link To This Post Posted: 14.Jan.2008 at 22:32
I've had similar problem, everytime I've switched between layout and model or different viewports, modelspace view was regenerated and everything got small (just like I was using ZOOM all). In my case setting UCSFOLLOW to 0 solved the problem.
http://www.cadaplus.com - AutoCAD plugin for architects with over 500 new commands ... and some free blocks :)
Back to Top
Newbie
Newbie
Status: Offline
Direct Link To This Post Posted: 14.Jan.2008 at 16:13
hey can anyone help
i dont no what, but i have done something to model when we insert a new plan in. when doing zoom then either all or Extent, the picture gets really small and goes to the left corner, now it should expand to the plan ful size to screen, i have tryed to look for anything else on the page but i cant see anything, can anyone help to fix??
Edited by 5han3 - 14.Jan.2008 at 16:14
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 0,145 seconds.
