RSS discussions
Discussion Discussion forum
Topic ClosedSimple Lisp Problem?
 Post Reply Post Reply
Author
jpkibble View Drop Down
Newbie
Newbie
Using: AutoCAD 2006
Status: Offline
Direct Link To This Post Topic: Simple Lisp Problem?
    Posted: 19.Nov.2010 at 17:01
I've recently been getting into Lisp with AutoCAD2006 with some success, however the following routine is giving me a headache.
It should draw a simple array of vertical lines 100 high at 25 unit intervals, it works fine but after a few test runs it starts doing funny things, missing every other line...missing lots of random lines or even spuriously joining lines to nearby objects. All very strange - have you any ideas why it might be happening?
(defun c:SPR ()
(setq leng (getint "Enter Length of Section in Metres:"))
(setq sectionstart (getpoint "\nPick Insertion point:"))
(setq aa (car sectionstart))
(setq bb (cadr sectionstart))
(setq rptn (+ 1 (fix (/ leng 25))))
(command "line" (list (+ aa leng) bb) (list (+ aa leng) (+ bb 100)) "")
; Repeat loop starts here
(repeat rptn
(command "line" (list aa bb) (list aa (+ bb 100) ) "")
(setq aa (+ aa 25))
; Repeat loop stops here
Edited by jpkibble - 19.Nov.2010 at 17:02
Back to Top
CarlB View Drop Down
Senior Member
Senior Member
Status: Offline
Direct Link To This Post Posted: 20.Nov.2010 at 07:20
Sounds like a common problem, for people learning Lisp...
You have a running Osnap set, so line snaps to an endpoint rather than the desired coordinate. It's erratic because it depends on the zoom level/pickbox size.
Back to Top
Newbie
Newbie
Using: AutoCAD 2006
Status: Offline
Direct Link To This Post Posted: 20.Nov.2010 at 08:55
That's great - problem solved with the use of OSMODE.
Thanks.Clap
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 0,258 seconds.
