Over 1.133.000 registered users (EN+CZ).
Discussion forum
Post Reply
| Author | |
Zap-Man
Newbie
Joined: 07.Jan.2011 Location: United States Using: AutoCAD LT Status: Offline Points: 1 |
Topic: Noobie QuestionsPosted: 07.Jan.2011 at 22:56 |
Hello, I am new to CAD drawings. My requirements are (I think) pretty basic. I need to be able to open existing .dwg files, which will be floor plans of buildings, and add icons for showing locations of items to be installed on the floor plan. It appears that AutoCAD LT is sufficient for my needs. Any opinions? Also, how intuitive is the program? Do I need to take a training class? I'm farily computer savvy. Any recommendations or helpful advice would be very much appreciated. Thanks! |
HAWDesigner
Senior Member
Joined: 04.Aug.2008 Location: United States Using: AutoCAD R14, AutoCAD 2009, AutoCAD 2010 Status: Offline Points: 310 |
Posted: 07.Jan.2011 at 23:11 |
From the sounds of it, you're correct, LT should be sufficient for your current needs.
You can, however, check this document to make sure that all of your needs are met with LT: AutoCAD versus AutoCAD LT Good Luck!! |
R. Williams AutoCAD 2010 Certified Professional <!-- If all else fails hit F1 --> <<AutoCAD 2009 |
Cad64
Senior Member
Joined: 17.Apr.2010 Location: United States Using: Autocad 2011, 3DS Max 2011, Photoshop CS5 Status: Offline Points: 491 |
Posted: 08.Jan.2011 at 05:14 |
I don't think you need to go to the expense of purchasing Autocad LT. ProgeCAD is only about half the price of LT, and is almost identical. And DoubleCAD XT is free. I would encourage you to take a look at those two programs before making a purchase.
Online Portfolio: http://www.rdeweese.com/
Post Reply
Tweet
This page was generated in 0,750 seconds.
Noobie Questions
Topic Options
