RSS discussions
Discussion Discussion forum
Topic ClosedNoobie Questions
 Post Reply Post Reply
Author
Zap-Man View Drop Down
Newbie
Newbie
Using: AutoCAD LT
Status: Offline
Direct Link To This Post Topic: Noobie Questions
    Posted: 07.Jan.2011 at 22:56
Hello,
 I am new to CAD drawings.  My requirements are (I think) pretty basic.   I need to be able to open existing .dwg files, which will be floor plans of buildings, and add icons for showing locations of items to be installed on the floor plan.
It appears that AutoCAD LT is sufficient for my needs.   Any opinions?
Also, how intuitive is the program?   Do I need to take a training class?   I'm farily computer savvy.
Any recommendations or helpful advice would be very much appreciated.
Thanks!
Back to Top
HAWDesigner View Drop Down
Senior Member
Senior Member
Using: AutoCAD R14, AutoCAD 2009, AutoCAD 2010
Status: Offline
Direct Link To This Post Posted: 07.Jan.2011 at 23:11
From the sounds of it, you're correct, LT should be sufficient for your current needs.
You can, however, check this document to make sure that all of your needs are met with LT: AutoCAD versus AutoCAD LT
Good Luck!!
R. Williams
AutoCAD 2010 Certified Professional
<!-- If all else fails hit F1 -->
<<AutoCAD 2009
Back to Top
Cad64 View Drop Down
Senior Member
Senior Member
Using: Autocad 2011, 3DS Max 2011, Photoshop CS5
Status: Offline
Direct Link To This Post Posted: 08.Jan.2011 at 05:14
I don't think you need to go to the expense of purchasing Autocad LT. ProgeCAD is only about half the price of LT, and is almost identical. And DoubleCAD XT is free. I would encourage you to take a look at those two programs before making a purchase.
Online Portfolio: http://www.rdeweese.com/
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 0,555 seconds.
