RSS discussions
Discussion Discussion forum
Topic ClosedPlotting Problem
 Post Reply Post Reply
Author
goodabomb View Drop Down
Newbie
Newbie
Using: AutoCAD2008
Status: Offline
Direct Link To This Post Topic: Plotting Problem
    Posted: 08.Jan.2011 at 21:32
I'm having trouble plotting to the correct scale. First off, I've already set my units to feets and inches, and I've finished my drawing as such. But when I'm ready to plot the scale factor on AutoCAD2008, the values are nothing that I would need to fit into a 24" x 36" paper, the scale I'm planning on putting was 1/8" = 1'-0".
Please let me know if you can help,
Thanks in advance.
P.S: if there's uncertainties about my problems, please let me know so i may further explain.
Back to Top
HAWDesigner View Drop Down
Senior Member
Senior Member
Using: AutoCAD R14, AutoCAD 2009, AutoCAD 2010
Status: Offline
Direct Link To This Post Posted: 10.Jan.2011 at 15:22
Care to play a game of 20 Questions?
1. Are you plotting via Modelspace or Paperspace?
R. Williams
AutoCAD 2010 Certified Professional
<!-- If all else fails hit F1 -->
<<AutoCAD 2009
Back to Top
Newbie
Newbie
Using: AutoCAD2008
Status: Offline
Direct Link To This Post Posted: 10.Jan.2011 at 20:36
I'm plotting on PS.
Would it make it easier if I plotted on MS?
I know that with model space I can zoom in and out when i'm viewing on the layout tab.
Back to Top
Senior Member
Senior Member
Status: Offline
Direct Link To This Post Posted: 10.Jan.2011 at 23:38
No, plotting via PS is optimal, don't change. Wink
From the sounds of it, you may need to either split your drawing or decrease the scale.
If you select the mview window, the "Viewport Scale" shows up in the bottom right corner of your workspace. Just click on the scale you want and it will adjust it for you.
Does this help?
R. Williams
<<AutoCAD 2009
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 0,087 seconds.
