Over 1.114.000 registered users (EN+CZ).
The new Beam calculator, Spirograph generator and Regression curves in the Converters section.
Discussion forum
Post Reply
Page 12> |
| Author | |
Rikky
Groupie
Joined: 30.Jul.2010 Using: 2004 2006 2007 2009 Status: Offline Points: 56 |
Topic: 2011 loft problemPosted: 07.Jan.2011 at 16:38 |
Hello,
At first.. My english is not verry good...
I work with AutoCAD 2011 and works a lot with 3D.
But now with 2011 when I try to loft, he makes a surface.
Now you can choose in loft between solid and a surface... And even when I choose for solid he wil make a surface...
Does somebody know what I do wrong or what I have to do to make a solid...
Thanks in advance.
Greetz,
Rikky
Autodesk Certified Engineer: ACE 3D Designer
AutoCAD 2011 professional |
HAWDesigner
Senior Member
Joined: 04.Aug.2008 Location: United States Using: AutoCAD R14, AutoCAD 2009, AutoCAD 2010 Status: Offline Points: 310 |
Posted: 07.Jan.2011 at 16:51 |
Hi Rikky. I will try to explain this with your lack of English Skills in mind.
You know that LOFT requires minimum 2 cross sections, correct? And you know what it means to have "Open" and "Closed" cross sections, correct? IF any one cross section is Open, the resulting LOFT will be a Surface. IF ALL cross sections are Closed, the resulting LOFT will be a Solid. Does this help? Edited by HAWDesigner - 07.Jan.2011 at 17:12 |
R. Williams AutoCAD 2010 Certified Professional <!-- If all else fails hit F1 --> <<AutoCAD 2009 |
HAWDesigner
Senior Member
Posted: 07.Jan.2011 at 17:26 |
Also Rikky, please see this: http://forums.autodesk.com/t5/AutoCAD-2011/Problem-with-lofting-in-2011/m-p/2733093#M4477
Note the attachment at the bottom of the post. |
Rikky
Groupie
Posted: 10.Jan.2011 at 13:15 |
The cross section is close... And at the last isnt my problem becease when I instal AutoCAD 2011 I could work LOFT and he make a perfecly soid...
But now a couple of weeks later he cant make a solid...
HAWDesigner
Senior Member
Posted: 10.Jan.2011 at 15:47 |
Ok, did you view the link I provided above?
Did that help? |
Rikky
Groupie
Posted: 11.Jan.2011 at 08:08 |
I viewed the link yes... But what I don't understand is that I have to make first a surface and than a solid...
Why is that I never did that before sow I am sure that some of the settings are wrong...
And I try the thing what the link said but I not really understand it...
Everybody Thank you verry mutch for helping hopaly it leads to a solution... Edited by Rikky - 11.Jan.2011 at 08:08 |
HAWDesigner
Senior Member
Posted: 11.Jan.2011 at 15:44 |
I understand your confusion. I was confused at first too. The poster "wengle" is incorrect. Follow the instruction of JDMather...and look at the image he posted.
Good Luck!! |
Rikky
Groupie
Posted: 12.Jan.2011 at 14:44 |
I know about the new function but even if I make sure he is on solid, he wil make surface... my steps,
View SW isometric.
make a circle by pressing c enter.
Than I make a region from this circle (it isnt nessesary but now I am sure he is closed)
I copy the circle over the Z axle
press loft mode is on solid...
And still he make a surface
(it doesnt make anny sence what for object it is...)
_______________________________________
Command: c CIRCLE Specify center point for circle or [3P/2P/Ttr (tan tan
radius)]: Specify radius of circle or [Diameter] <0.3967>: 1 Command: region Select objects: Specify opposite corner: 1 found Select objects: 1 loop extracted. 1 Region created. Command: Specify opposite corner: Command: Specify opposite corner: Command: co COPY 1 found Current settings: Copy mode = Multiple Specify base point or [Displacement/mOde] <Displacement>: Specify second point or <use first point as displacement>: 1.5 Specify second point or [Exit/Undo] <Exit>: *Cancel* Command: loft Current wire frame density: ISOLINES=4, Closed profiles creation mode = Solid Select cross sections in lofting order or [POint/Join multiple edges/MOde]: 1 found Select cross sections in lofting order or [POint/Join multiple edges/MOde]: 1 found, 2 total Select cross sections in lofting order or [POint/Join multiple edges/MOde]: 2 cross sections selected Enter an option [Guides/Path/Cross sections only/Settings/COntinuity/Bulge magnitude] <Cross sections only>: Command: Specify opposite corner: Command: _______________________________________________
so you can see...
HAWDesigner
Senior Member
Posted: 12.Jan.2011 at 16:20 |
I see. Ok, I followed your steps and produced a "3DSOLID". I also tried it with a Circle and with a Region and both were the same. That leads me to believe that it may be a lofting setting in your system that could be set incorrectly.
Here are my lofting System Variable settings: LOFTANG1 = 90d LOFTANG2 = 90d LOFTMAG1 = 0.0000 LOFTMAG2 = 0.0000 LOFTNORMALS = 1 LOFTPARAM = 7 Maybe you can try setting yours to the same and trying again? Good Luck!! |
Rikky
Groupie
Posted: 13.Jan.2011 at 15:40 |
I acutaly checked them before I asked this question and they are the same haha. So it is a verry strange problem...
Do you have more options?
Again thank you terry verry mutch for helping! I appreciate it verry mutch!
Post Reply
Page 12> |
Tweet
This page was generated in 0,090 seconds.
![CAD Forum - tips, tricks, discussion and utilities for AutoCAD, Inventor, Revit and other Autodesk products [www.cadforum.cz] CAD Forum - tips, tricks, discussion and utilities for AutoCAD, Inventor, Revit and other Autodesk products [www.cadforum.cz]](/common/arkance_186.png)
2011 loft problem
Topic Options
