RSS discussions
Discussion Discussion forum
Topic Closedhelp with viewports
 Post Reply Post Reply
Author
Joferna View Drop Down
Groupie
Groupie
Using: Autocad 2008
Status: Offline
Direct Link To This Post Topic: help with viewports
    Posted: 15.Jan.2011 at 03:46
Is there a way to draw on one viewport  without the drawing appearing on the other viewport simultaneously.?   I  tried  by dividing the screen   with 2 viewports from the view pulldown menu . But whenever I draw on the active viewport, the drawing appears on the other viewport as well.
 I have only been successful in panning the parallel drawing(unwanted) out of the  other viewport
Edited by Joferna - 15.Jan.2011 at 03:48
Back to Top
HAWDesigner View Drop Down
Senior Member
Senior Member
Using: AutoCAD R14, AutoCAD 2009, AutoCAD 2010
Status: Offline
Direct Link To This Post Posted: 16.Jan.2011 at 15:05
Yes, turn the layer off in the other viewport.
R. Williams
AutoCAD 2010 Certified Professional
<!-- If all else fails hit F1 -->
<<AutoCAD 2009
Back to Top
Groupie
Groupie
Using: Autocad 2008
Status: Offline
Direct Link To This Post Posted: 17.Jan.2011 at 05:58
Thanks Rob - But I have a 2008 version - is there another way to do this?
I understand it is easy to do in 2011 version  through the layer manager
Back to Top
CarlB View Drop Down
Senior Member
Senior Member
Status: Offline
Direct Link To This Post Posted: 17.Jan.2011 at 07:13
No, in model space viewports you cannot control layers by viewport; draw something in one and it shows in all.
You can control layers by viewport, for vieweports in paper space (on layout tabs).
Back to Top
Senior Member
Senior Member
Status: Offline
Direct Link To This Post Posted: 17.Jan.2011 at 15:23
My apologies for not being clear enough before. In order for you to accomplish what you want, all you need to do is Freeze the Layer in the current view port. To do so is very common and extremely simple.
1. Set the view port that you want to 'active'.
2. Using the Layers Toolbox, Freeze the layers that you don't want in the active viewport (3RD Icon from the Left).
3. See the results:
This IS what you inquired about, correct? Or did I misread your question?
Edited by HAWDesigner - 17.Jan.2011 at 15:29
R. Williams
<<AutoCAD 2009
Back to Top
Senior Member
Senior Member
Status: Offline
Direct Link To This Post Posted: 17.Jan.2011 at 15:25
Oh, and those are Paperspace Viewports, not Modelspace. Wink
R. Williams
<<AutoCAD 2009
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 0,065 seconds.
