RSS discussions
Discussion Discussion forum
Topic Closedblock attribute problem
 Post Reply Post Reply
Author
clicker View Drop Down
Newbie
Newbie
Using: autodac 2008
Status: Offline
Direct Link To This Post Topic: block attribute problem
    Posted: 01.Feb.2011 at 03:04
Burning question...
I had a block definition that i've inserted into my drawing multiple times.I added an editable attribute to the block definition, but when I did so, the blocks that were inserted previously did not update with the editable attribute attached.... It appears that the editable attribute will only be assigned to blocks which are inserted after the attribute is assigned... is this true?
Please help!
Back to Top
Lexxx View Drop Down
Newbie
Newbie
Using: Civil3D 2012, MicrostationV8i, PathPlanner
Status: Offline
Direct Link To This Post Posted: 01.Feb.2011 at 10:48
Try ATTSYNC
lex
Back to Top
gbtjom View Drop Down
Newbie
Newbie
Using: AutoCAD 2005 LT
Status: Offline
Direct Link To This Post Posted: 01.Feb.2011 at 21:15
Hello
I'm also VERY new to AutoCAD (2005 LT) and have a similar problem.  In my case, I updated the attribute to be larger (height) so that could read the drawings better.  All of the blocks I had put down previously did NOT update the size of the attribute in each of those instances.  I really do NOT want to put down 100 or so of these instances again while re-adding the attribute values for each.  argh.
The command "ATTSYC" is "unknown" in my version of AutoCAD 2005 LT.  Any other work arounds?
Thanks for any help you can give.
jom
Back to Top
HAWDesigner View Drop Down
Senior Member
Senior Member
Using: AutoCAD R14, AutoCAD 2009, AutoCAD 2010
Status: Offline
Direct Link To This Post Posted: 01.Feb.2011 at 21:46
Try ATTREDEF.
Good Luck!!
R. Williams
AutoCAD 2010 Certified Professional
<!-- If all else fails hit F1 -->
<<AutoCAD 2009
Back to Top
Senior Member
Senior Member
Status: Offline
Direct Link To This Post Posted: 01.Feb.2011 at 21:48
OOPS!! Command not available in AutoCAD LT.
Sorry, that's one of the benefits to owning the full version.
R. Williams
<<AutoCAD 2009
Back to Top
Newbie
Newbie
Status: Offline
Direct Link To This Post Posted: 02.Feb.2011 at 14:32
Same problem
ATTSYNC in LT since 2010.
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 0,090 seconds.
