RSS discussions
Discussion Discussion forum
Topic ClosedLISP Error
 Post Reply Post Reply Page  <12
Author
kameron1967 View Drop Down
Groupie
Groupie
Using: autocad 2018
Status: Offline
Direct Link To This Post Posted: 23.Feb.2011 at 02:24
Thanks, CarlB.  You're a savior!
Back to Top
CarlB View Drop Down
Senior Member
Senior Member
Status: Offline
Direct Link To This Post Posted: 23.Feb.2011 at 02:06
OK since my name was mentioned..here's my take at a simple lisp..
(defun C:NEWL ();R-1
   (setq PickItem (car (entsel "\nPick object for new layer: ")));R-1
   (setq ObjLayer (cdr (assoc 8 (entget pickItem))));R-1
   (setq ObjType (cdr (assoc 0 (entget pickItem))));R-1
   (princ (strcat ObjLayer " is layer name of " ObjType " selected"));R-1
   (initget "N D V");R-1
   (Setq LyrSuffix (getkword "\nEnter suffix type [N-PKG-1/D-PKG1/V-PKG-1]:"));R-1
   (setq NewLyrName
      (cond
         ((= LyrSuffix "N") (strcat ObjLayer "-N-PKG-1" ))
         ((= LyrSuffix "D") (strcat ObjLayer "-D-PKG-1"))
         ((= LyrSuffix "V") (strcat ObjLayer "-V-PKG-1"))
    (command "._Layer" "_M" NewLyrname "")
   (princ)
Back to Top
Groupie
Groupie
Using: autocad 2018
Status: Offline
Direct Link To This Post Posted: 22.Feb.2011 at 18:00
yes, you're right.  It was taken from various source.  I need to somehow tie them all in so that whatever letter I choose, it appends the right suffix to the new layer that it will be creating.
If anyone has a shortcut to creating a simple layer modifer, I'd love to see it.  Basically, if N is chosen, it will add the -N-PKG1 in the new layer based on the entity selected.  Thanks.
Back to Top
Vladimir Michl View Drop Down
Moderator Group
Moderator Group
Using: Autodesk software
Status: Offline
Direct Link To This Post Posted: 22.Feb.2011 at 14:58
Yes, this is one of the ways how to do it. This LISP code seems to be mixed from several sources - the names of layer variables are mixed: objlayer, LYR, nlayer.
Assumes e.g. that objlayer is already filled with the old layer name.
Vladimir Michl (moderator)
Back to Top
HAWDesigner View Drop Down
Senior Member
Senior Member
Using: AutoCAD R14, AutoCAD 2009, AutoCAD 2010
Status: Offline
Direct Link To This Post Posted: 22.Feb.2011 at 14:00
I'm not an expert on LISP yet, sorry. Finding syntax errors is about as far as my LISP abilities go. Perhaps CarlB can lend you a hand on this.
Good Luck!!
R. Williams
AutoCAD 2010 Certified Professional
<!-- If all else fails hit F1 -->
<<AutoCAD 2009
Back to Top
Groupie
Groupie
Using: autocad 2018
Status: Offline
Direct Link To This Post Posted: 22.Feb.2011 at 01:43
Thanks.  So if I wanted to create a new layer based on the entity that I selected (for instance a line on H-ROOM layer), how would I attach the modifier to that entity so that if I choose D for suffix, it will automatically create a new layer based on the entity so that the new layer would look like this: H-ROOM-D-PKG1?  Thanks.
Would it be something like this..?
      (setq oLayers
      (vla-get-layers
        (vla-get-activedocument
   (vlax-get-acad-object))))
(if (not (tblsearch "LAYER" objlayer))
       (progn
         (setq LyrNew (vla-add oLayers LYR)
        LyrTab (vla-item oLayers sLYR)
  (vla-put-linetype LyrNew (vla-get-linetype LyrTab))
  (vla-put-truecolor LyrNew (vla-get-truecolor LyrTab))
  (vla-put-freeze LyrNew (vla-get-freeze LyrTab))
  (vla-put-layeron LyrNew (vla-get-layeron LyrTab))
  (vla-put-lineweight LyrNew (vla-get-lineweight LyrTab))
  (vla-put-lock LyrNew (vla-get-lock LyrTab))
  (vla-put-material LyrNew (vla-get-material LyrTab))
  ;(vla-put-plotstylename LyrNew (vla-get-plotstylename LyrTab))
(setq ent (car(entsel)))
(setq nlayer
(cdr (assoc 8 (entget ent)))
(setq LyrNew (strcat LYR lyrsuffix))
Edited by kameron1967 - 22.Feb.2011 at 01:50
Back to Top
Senior Member
Senior Member
Status: Offline
Direct Link To This Post Posted: 21.Feb.2011 at 23:27
The initial error I got was "ERROR: malformed string on input".
By changing Line7 to the following, it cleared that error, but every time I enter a suffix type, I now get the error: "Invalid Option Keyword"
NOTE: You were missing a " (quote) between ObjLayer and is.
Edited by HAWDesigner - 21.Feb.2011 at 23:29
R. Williams
<<AutoCAD 2009
Back to Top
Groupie
Groupie
Using: autocad 2018
Status: Offline
Direct Link To This Post Posted: 21.Feb.2011 at 22:11
Hi.  Someone helped me with this, but I'm not able to get it to run. It has a syntax error.
[CODE]
(vl-load-com);R-1
(princ (strcat ObjLayer is layer name of " ObjType " selected"));R-1
);R-0
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 0,085 seconds.
