RSS discussions
Discussion Discussion forum
Topic ClosedRibbon not working
 Post Reply Post Reply
Author
AnnieC View Drop Down
Groupie
Groupie
Using: autoCAD 2012
Status: Offline
Direct Link To This Post Topic: Ribbon not working
    Posted: 04.Apr.2011 at 21:04
Big problem.. I am working in AutoCAD 2011 and after a few minutes the ribbon panels turn all light and I cannot click on any short cut.  i type RIBBON and nothing happens... HELP!!!
Back to Top
John Connor View Drop Down
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 05.Apr.2011 at 12:22
Turns light?  As in transparent?
Have you tried shutting everything down then rebooting?
What were you doing when the problem first occurred?
Are you using any custom lisp routines?
Are you working on a 2D or 3D drawing?
Anything unique about the drawing you were working on when the problem occurred?  What is the source of the drawing?
<<AutoCAD 2015>>
Back to Top
Groupie
Groupie
Using: autoCAD 2012
Status: Offline
Direct Link To This Post Posted: 05.Apr.2011 at 14:50
hello John.. I have tried rebooting many times.  it does turn transparent.  What happend was that I was working  normally and clicked on the ribbon and it disappeared so in trying to get the ribbon back the old 2007 Autocad shortcuts appeared and i started using them. then i figured out the ribbon and put them up.  That's when the problem started.  So i got rid of all the old autocad buttons and it is still happening.  I am not running 3d and never will.  thanks for responding.
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 05.Apr.2011 at 18:32
I'm not even going to ask about the "old AutoCAD 2007 shortcuts".
So, how did you figure out the Ribbon?
<<AutoCAD 2015>>
Back to Top
Groupie
Groupie
Using: autoCAD 2012
Status: Offline
Direct Link To This Post Posted: 05.Apr.2011 at 19:40
i typed RIBBON and a huge bunch of menus came up.  It took up my whole screen.  So i unclicked on the ones i did not need and kept the ribbon to the menus that i use.  Then i save my settings.
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 05.Apr.2011 at 23:18
I cannot think of a plausible reason why your Ribbon would suddenly get "lighter".  Have you thought about running the REPAIR option?
No other program is experiencing graphic-related problems similar to what you are seeing in AutoCAD?
<<AutoCAD 2015>>
Back to Top
Groupie
Groupie
Using: autoCAD 2012
Status: Offline
Direct Link To This Post Posted: 05.Apr.2011 at 23:31
I DONT have another graphic program. how do i run repair???
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 06.Apr.2011 at 12:36
Annie: "graphic-related" refers to what you see on your screen and not to another program similar to AutoCAD.
The REPAIR option is accessed via Windows Add/Remove Programs in the Control Panel.  Windows will build an index of the programs on your hard drive and list them in alphabetical order.  You scroll down the list until you find AutoCAD 2011 and under that there should be the option to REPAIR or REINSTALL.  Have your media (DVD) nearby in case it prompts you to insert it.
<<AutoCAD 2015>>
Back to Top
shirleykings View Drop Down
Newbie
Newbie
Using: autocad2011
Status: Offline
Direct Link To This Post Posted: 06.Apr.2011 at 15:11
I have tried rebooting many times. But i haven't make it.
http://www.nikehotsale.com offer cheap air jordan 2010,air jordan 1 shoes.
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 06.Apr.2011 at 18:13
What problem are you experiencing?
If it is different than the problem AnnieC is having why not consider starting a new thread so the two discussions don't get mixed together?  OK?
<<AutoCAD 2015>>
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 0,098 seconds.
