RSS discussions
Discussion Discussion forum
Topic ClosedDrawing using %?
 Post Reply Post Reply
Author
jmontesmx View Drop Down
Senior Member
Senior Member
Using: AutoCad2017
Status: Offline
Direct Link To This Post Topic: Drawing using %?
    Posted: 18.Jan.2012 at 05:53
Erroneously indicate 50% instead of 0.5%, if one line is a must have this slope, the procedure may be  Dave also, but if you need draw an entire plane try UCS command and adjust the angle in the X axis for the slope you need, and finally returns back to X axis at 0
Back to Top
heinsite View Drop Down
Senior Member
Senior Member
Using: AutoCAD 2014
Status: Offline
Direct Link To This Post Posted: 17.Jan.2012 at 09:04
0.5% = 0.5/100 = 0.005.  Think rise over run.  In this case for every unit of run there will be a rise of 0.005 units.  You don't need to know the length of the line to set this slope.  You can just set up an angled construction line thru the origin using this as a guide and draw a line on it at any length you like.
Dave
Dave Hein, P.E.
Hawaii District Engineer
Kona International Airport
AutoCAD Certified Professional
Back to Top
Senior Member
Senior Member
Using: AutoCad2017
Status: Offline
Direct Link To This Post Posted: 17.Jan.2012 at 01:51
to obtain 50% slope, you first need to know the length of the line, then multiply this by .5 and you will have the difference in length in the Y axis between the origin point of your line and the end point of this to have a 50 % slope, to find the angle, use the inverse tangent function.
I hope this helps.
Back to Top
John Connor View Drop Down
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 12.Jan.2012 at 16:56
Maybe this will help.
http://www.engineeringtoolbox.com/slope-degrees-gradient-grade-d_1562.html
Once you know the number of degrees you can use direct distance entry at the command line.
Example: @7.5<45
This would be read as 7.5 units long at an angle of 45 degrees.
Edited by John Connor - 12.Jan.2012 at 16:59
<<AutoCAD 2015>>
Back to Top
surfgreenfender View Drop Down
Newbie
Newbie
Using: AutoCAD 2004, AutoCAD Civil, AutoCAD LDD 2004
Status: Offline
Direct Link To This Post Posted: 12.Jan.2012 at 16:08
So i need to draw a line at a 0.50% slope.
Never drawn that way before.
Whats the command for that??
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 0,082 seconds.
