RSS discussions
Discussion Discussion forum
Topic ClosedAutoCAD Questions
 Post Reply Post Reply Page  <123>
Author
heinsite View Drop Down
Senior Member
Senior Member
Using: AutoCAD 2014
Status: Offline
Direct Link To This Post Posted: 09.May.2012 at 06:56
Yeah, that's part of your problem right there.  WBLOCK and INSERT are two completely different operations.  WBLOCK takes a set of objects and writes them out to the disk as a completely new DWG file.  INSERT takes a drawing or a block and places it in a drawing.
By any chance is it the "template" file (either as a dwg or a block) the part you're trying to put into the Layout?  Is it a title block by any chance?
A word of explanation is in order at this point too.  Your subdivision, or whatever it is, is entirely in Model space, and is drawn to real scale... probably a thousand feet (or meters) or more on a side.  But it's real scale, full units  Stuff in model space is always drawn full scale whether it's in millimeters or parsecs.  But Layout space, otherwise known as Paper space, is just used for prints, plots, or display.  It is not in real units.  It's scaled to fit the medium, and is our Viewport, or window, thru which we look at our drawing.  Think of it as a window you look thru to see your model.  But you create the window.  It's called a Viewport, and you draw it in paper space.  Without a Viewport you can't see the model.
Now explain again what you're trying to do.
Dave.
Dave Hein, P.E.
Hawaii District Engineer
Kona International Airport
AutoCAD Certified Professional
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2014
Status: Offline
Direct Link To This Post Posted: 09.May.2012 at 07:01
> ... drawing in a rectangle with some information on it (drawn by: , Assignment #:, etc.) and he calls it a template.
Between you and me, he should call it a Title Block, because that's what it is.  And that's the terminology you'll hear when you start doing drawings you get paid for.  Template files *can* include title blocks, but they don't have to.
Dave.
Dave Hein, P.E.
Back to Top
samdesign View Drop Down
Newbie
Newbie
Using: 2012
Status: Offline
Direct Link To This Post Posted: 09.May.2012 at 08:20
Please guys anybody can help me that how to create a lisp file?
sameer
Mercury
Qatar
Back to Top
Newbie
Newbie
Using: 2012
Status: Offline
Direct Link To This Post Posted: 09.May.2012 at 08:24
 I am working mostly in infrastructure projects by using cad-2012.
My problem that when i will bind my x-refs, the file size increasing.eg:95MB,105MB 85MB etc...   How can i reduce maximum of a dwg file size?
sameer
Mercury
Qatar
Back to Top
chickenjoe View Drop Down
Newbie
Newbie
Using: AutoCAD2011
Status: Offline
Direct Link To This Post Posted: 09.May.2012 at 08:34
Yes I meant the title block. I am sorry.
Right now, I have a top view of a block (with roads and houses), top view of a house, front view of a house, and parts (doors, windows, garage, etc.) with dimensions in 1 big drawing
So here, I am trying to place my title block on my Layout and place parts of my drawing in the title block. I am lost how to do this.
Back to Top
John Connor View Drop Down
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 09.May.2012 at 11:57
Insert your title block and border in your layout.
Next, create at least one viewport.  A viewport is like a window that allows the user to look at the objects that were created back in model space.
Viewports can be resized with their grips.
Viewports can be moved, copied, rotated and even deleted.
It's a good idea to put viewports on their own layer and set the layer to "no print" in the Layer Properties Manager.
Viewports are assigned a scale not the objects back in model space.  They should all be drawn at full size.
Viewports, after having a scale assigned to them, to have their display locked (can do this via the Properties palette) so as to prevent accidentally changing the scale when moving between paper space and model space.
Viewports can be created using the MView command.
<<AutoCAD 2015>>
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2014
Status: Offline
Direct Link To This Post Posted: 09.May.2012 at 13:06
Yeah, as John says, first you insert the title block (what your prof calls a template - I'm convinced he's trying to confuse you) on the Layout tab.  Insert it on Layer 0 (in other words, make Layer 0 current before you insert), and make sure you insert at 0,0.   More than likely it's been created so that 0,0 is the insertion point.
Once you have the block in the Layout you can "cut a hole in it".  This is the viewport.  A bit of magic will happen when you first do this as your model will suddenly appear!  It will be sized as if you just zoomed extents.  It will fill the viewport.  You can work on the model from here by double clicking anywhere inside the viewport.  When you double click back outside you'll return to paper space.  Double clicking inside the viewport is called, "activating" the view.  To resize the model in the viewport click on the edge of the viewport and change the scale setting on the Status bar.  You will only see the scale setting by clicking the viewport edge.  Now you'll see what happens to your text objects to fixed height text when you change display scales.
There's much more to learn here.  But you're getting started.  :)
Dave.
Dave Hein, P.E.
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2014
Status: Offline
Direct Link To This Post Posted: 09.May.2012 at 13:13
samdesign:  This is called, "hijacking" a thread.  Don't do it.  It's off-topic, confusing and makes finding things later next to impossible.
Don't expect an answer until you start a new thread with a new post and an appropriate subject line and ask the question again.  Then you'll not only get responses but allow others to see what the subject is and join in.
Dave
Dave Hein, P.E.
Back to Top
RoboFutbol View Drop Down
Newbie
Newbie
Using: AutoCAD 2013, Inventor 2013
Status: Offline
Direct Link To This Post Posted: 09.May.2012 at 15:32
I've never forgot my prof's explanation of paper space. He said, "Take a piece of paper with your title block on it, cut an opening in it and that is a viewport." Of course you can then scale the viewport to see any scaled object you drew in model space. Multiple viewports on one page can have different scales as needed as well.
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 09.May.2012 at 18:30
That is a good analogy.
<<AutoCAD 2015>>
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 0,324 seconds.
