RSS discussions
Discussion Discussion forum
Topic Closedautolisp need help
 Post Reply Post Reply
Author
samlimct View Drop Down
Newbie
Newbie
Status: Offline
Direct Link To This Post Topic: autolisp need help
    Posted: 30.May.2008 at 10:29
(DEFUN C:Gq (/)
  (GRAPHSCR) ; CHANGE TO GRAPHIC SCREEN
  (SETQ L ( GETREAL" ENTER LENGTH OF GASKETS " )) (terpri)
  (setq cog ( getpoint " enter corner of gasket " )) (terpri)
  (setq x1 (car cog )) (terpri)
  (setq y1 (cadr cog )) (terpri)
  (setq x2 (+ x1 L)) (terpri)
  (setq x3 (+ x1 L (/ L 2 ))) (terpri)
  (setq x4 (+ x1 (/ L 2 ))) (terpri)
  (setq ang (sin ( / pi 3 )))(terpri)
  (setq height1 (* L ang )) (terpri)
  (setq y3 ( + y1 height1)) (terpri)
  (setq y4 ( + y1 height1)) (terpri)
  (setq pnt1 ( list x2 y1 )) (terpri)
  (setq pnt2 (list x3 y3 )) (terpri)
  (setq pnt3 (list x4 y4 )) (terpri)
  (command "line" cog pnt1 pnt2 pnt3 "c" "" ) (terpri)
     (prompt " change polyline")(terpri)
  (command " pedit"  "m" (ssget) "" "y" "j" cog pnt1 pnt2 pnt3 "")(terpri)
 HI good morning all,
i'm autolisp beginner. i had write the program on  the top but i trying to change the line into polyline. but doest'nt work. anyone can help to have a  check.
thanks very much....
sam
Back to Top
maungthantzinoo View Drop Down
Newbie
Newbie
Status: Offline
Direct Link To This Post Posted: 03.Jun.2008 at 11:45
You try below lisp instead of your...
(command
"pedit" "m" (ssget) "" "y" "j" "" "")(terpri)
Back to Top
Newbie
Newbie
Status: Offline
Direct Link To This Post Posted: 03.Jun.2008 at 17:36
hi
your program only can be separate use for changing to polyline but does'nt work together with my grasket line.
anyway thanks for your help
sam
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 0,066 seconds.
