RSS discussions
Discussion Discussion forum
Topic ClosedPatch Package Help
 Post Reply Post Reply Page  12>
Author
Kipper View Drop Down
Groupie
Groupie
Using: AutoCAD LT 2006
Status: Offline
Direct Link To This Post Topic: Patch Package Help
    Posted: 25.Oct.2012 at 00:33
I get a message that "patch package can not be opened. Verify that the patch package exists and that you can access it, or contact the application vendor to verify that this is a valid windows installer patch package" when I try to re-install AutoCAD LT 2006. I am running Microsoft Windows XP Professional service pack 3. Any help would be appreciated.
Kipper
Edited by Kipper - 25.Oct.2012 at 00:37
Back to Top
heinsite View Drop Down
Senior Member
Senior Member
Using: AutoCAD 2014
Status: Offline
Direct Link To This Post Posted: 25.Oct.2012 at 05:58
Sometimes things go so haywire in AutoCAD that the only way to reinstall the program successfully is to completely remove all traces of everything Autodesk on your computer.  The recommended guidelines can be found here:
How to remove all Autodesk products from a Windows system.
Then run your installation again from the ground up.  Don't forget to check for and include any service packs or hotfixes for that release as well.
Dave
Edited by heinsite - 25.Oct.2012 at 06:01
Dave Hein, P.E.
Hawaii District Engineer
Kona International Airport
AutoCAD Certified Professional
Back to Top
Groupie
Groupie
Status: Offline
Direct Link To This Post Posted: 26.Oct.2012 at 10:40
DAVE                                                      Thanks for your reply. I tried my hand at this but I'm sure I went wrong somewhere. Now every time I try to open my CAD program, it stays open for about ten seconds and then closes and I get the "Sorry AutoCAD had to close" box. This is about to tear me up. Any suggestions on what to do.   Thanks again                            Kip
Back to Top
John Connor View Drop Down
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 26.Oct.2012 at 11:50
Where did you get your copy of AutoCAD LT 2006?
<<AutoCAD 2015>>
Back to Top
Groupie
Groupie
Status: Offline
Direct Link To This Post Posted: 26.Oct.2012 at 15:11
I don't really know. It was bought by our former Public Works Director. I would probably guess he would have purchased it at a computer outlet store.
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 26.Oct.2012 at 20:40
So you did an uninstall following the recommendations as set forth by AutoDesk then you tried to reinstall but it failed?
What do you use AutoCAD LT to do anyways?
Did you know that there is a free, yes "free", 2D AutoCAD-clone program called Draftsight?  And guess what?  It is a lot more up-to-date than your version of AutoCAD LT 2006 is.  The best thing is the commands and look are very similar to AutoCAD.  A free PDF manual is also available as a download too.
Do you really want to keep messing around trying to reinstall LT?  What forced you to install it the first time?  Did you have a hard drive crash?
Edited by John Connor - 26.Oct.2012 at 20:44
<<AutoCAD 2015>>
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2014
Status: Offline
Direct Link To This Post Posted: 26.Oct.2012 at 23:21
I have the same question as John did... is your AutoCAD LT 2006 installation on a CD/DVD?  Do you have the original packaging?  Or is the installation all coming from a file on your system somewhere?  Are you absolutely sure the copy that originally worked was legal and registered?
Hate to be going down this path but something doesn't sound quite right.  I've saved all my old original installation disks and have never had a problem re-installing an older version as far back as LT 2004.  But you do need all the proper information and have to be methodical when rebuilding.
Dave.
Dave Hein, P.E.
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 28.Oct.2012 at 15:53
2006 would have most likely been on a CD.
<<AutoCAD 2015>>
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2014
Status: Offline
Direct Link To This Post Posted: 28.Oct.2012 at 22:41
I never could keep them straight. Embarrassed
Dave Hein, P.E.
Back to Top
Groupie
Groupie
Status: Offline
Direct Link To This Post Posted: 30.Oct.2012 at 14:50
I took my computer to get repaired and they had the same problem as I did. They downloaded Autodesk Design Review 13 and I can at least open up drawings, but I cant find some icons. Can you give me instructions on how to download Draftsight. Please Please Help. I have End of the Month Reports due by the 15th (of last month).       Thanks, Kip
Edited by Kipper - 30.Oct.2012 at 21:48
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 0,091 seconds.
