RSS discussions
Discussion Discussion forum
Topic ClosedUnits problem HELP!!
 Post Reply Post Reply
Author
hacksaw View Drop Down
Newbie
Newbie
Using: Autocad 2010
Status: Offline
Direct Link To This Post Topic: Units problem HELP!!
    Posted: 20.Nov.2012 at 05:03
Hi guys,
I make a CAD drawing that I was unaware that someone has change the units by default from millimeters to inches, I'm almost half to finish until I found out that it was in wrong units, is any other way to change my drawing units without changing the preffered dimensions (e.g. 210 inches to 210 millimeters) please help I was new to autocad but I didn't know how to fixed this one..
"Remember Remember the fifth of November"
Back to Top
heinsite View Drop Down
Senior Member
Senior Member
Using: AutoCAD 2014
Status: Offline
Direct Link To This Post Posted: 20.Nov.2012 at 05:53
If you continued drawing unaware that the UNITS change had been made, AND you continued entering your lengths and dimensions as if they still were in millimeters, the change probably had no effect on your work.  Just be sure that you correct the UNITS settings before going much further.  You might also want to ask that other person what they were thinking when they made the change.
A random check throughout the drawing of dimensions is probably a good idea too.
Dave.
Dave Hein, P.E.
Hawaii District Engineer
Kona International Airport
AutoCAD Certified Professional
Back to Top
Newbie
Newbie
Using: Autocad 2010
Status: Offline
Direct Link To This Post Posted: 20.Nov.2012 at 06:41
Does Scale using Reference would take effect?? I import the inches drawing to a millimeter units autocad and scaled it using the reference (e.g. 21.48 inches now converted to 1+ millimeter length of line after being imported and then I draw a a reference line having a length of 21480 millimeter and click both point), does the drawing accuracy would lost or would be still the same??
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2014
Status: Offline
Direct Link To This Post Posted: 20.Nov.2012 at 11:18
Without knowing how your two drawings were set up it's kind of hard to predict what's going to happen.  But I would suggest you create some instructional example files for yourself as a teaching aid.  They may help you understand this more quickly than anyone here could explain it.
Start a new drawing using the ACADISO template.  This will be decimal lengths and millimeter insertion units.  Create a square box 25.4mm x 25.4mm and dimension it.  Save the file as SQ-MM.
Now start another drawing using the ACAD template.  With the UNITS command set the length type to Decimal and the Insertion scale to Feet.  Import or attach your SQ-MM drawing.  Zoom extents if you can't see it.  Use the MEASUREGEOM command to check the lengths.  They should be 0.0833' (1" or 25.4mm) long each.  AutoCAD did the conversion for you.
Start one more drawing using the ACAD template.  This time set the length type to Architectural and the Insertion scale to Inches.  Import or attach your SQ-MM drawing again and check the lengths.  This time they should be equal to 1".
I think this little exercise will go a long way toward helping you understand how the Units and Insertion scale settings work between drawings.
Dave.
Dave Hein, P.E.
Back to Top
John Connor View Drop Down
Senior Member
Senior Member
Using: AutoCAD 2018
Status: Offline
Direct Link To This Post Posted: 20.Nov.2012 at 11:42
You can change units via the -DWGUNITS command.
<<AutoCAD 2015>>
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 0,172 seconds.
