RSS discussions
Discussion Discussion forum
Topic ClosedMtext Question
 Post Reply Post Reply
Author
Arben.Allaraj View Drop Down
Senior Member
Senior Member
Using: AutoCAD 2008
Status: Offline
Direct Link To This Post Topic: Mtext Question
    Posted: 08.Jul.2008 at 17:23
Originally posted by APD1013 APD1013 wrote:
I went into MTEXTED  and changed it from "internal" to "oldeditor".  It works again, but is still ends up at 270 deg.  I tried changing it back to "internal", but the command does not go through anymore at all.  I'll try a cold boot and see if that helps._popupControl();
Type style in command line and check the option backwards.?
Ing Arben.Allaraj
http://cad-drafting-corner.blogspot.com
Back to Top
Vladimir Michl View Drop Down
Senior Member
Senior Member
Using: Autodesk software
Status: Offline
Direct Link To This Post Posted: 08.Jul.2008 at 16:24
Try to select a different font in the STYLE settings for your texts. You can also edit the text with DDEDIT.
Vladimir Michl
//CADs.cz, LinkedIn
Back to Top
APD1013 View Drop Down
Newbie
Newbie
Status: Offline
Direct Link To This Post Posted: 04.Jul.2008 at 01:21
Back to Top
Newbie
Newbie
Status: Offline
Direct Link To This Post Posted: 03.Jul.2008 at 23:38
I had already checked that and it was set to the default of 2...  I just tried it at 1 and that worked, but text was too small in the editor.  When I switched it back to 2, something happened and now the Editor does not appear when you create the text box with the cursor.  There is a pause, then nothing.  Yikes! Is there something else in that I should be looking at?  I'm going close AutoCAD and  re-boot my computer to see if that helps...
Thank you for your comments thus far!
_popupControl();
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2008
Status: Offline
Direct Link To This Post Posted: 03.Jul.2008 at 18:51
Thank you.  My UCS is set to "World", Top 0'-0".  I also went into Units Format and made sure that the direction was set to base angle East (0.00).  Still no permanent change to the MText orientation of 270 deg.  (Oddly, it occasionally works correctly but not ever on a permanent basis.)
So... help is still needed.  Thanks!
_popupControl();
Can you use this variable:
MTEXTFIXED
Ing Arben.Allaraj
Back to Top
Newbie
Newbie
Status: Offline
Direct Link To This Post Posted: 03.Jul.2008 at 17:10
_popupControl();
Back to Top
Senior Member
Senior Member
Using: AutoCAD 2008
Status: Offline
Direct Link To This Post Posted: 03.Jul.2008 at 11:43
 Check the UCS plane.
Ing Arben.Allaraj
Back to Top
Newbie
Newbie
Status: Offline
Direct Link To This Post Posted: 01.Jul.2008 at 19:56
Hello!
I hope you can help me.  I have a recurring problem with my Mtext Editor (AutoCAD 2007) - It always reverts back to a 270 deg. rotation.  For example, every time I go to edit an existing text (shown at 0 deg), it rotates 270.  If I go ahead and make the changes in that format, it stays that way when I am done.  I have to go to Properties to change the rotation back to zero.  Very frustrating!
FYI - The same thing happens with new text - the cursor used to create the text box has the "abc" shown at 270 deg and creates the text sideways.  None of this makes for efficiency...
Thanks in advance for your help!
_popupControl();
Back to Top
Related CAD tips:
  Share Topic
This page was generated in 0,094 seconds.
